[加密問題] gcin在終端機顯示的拆碼記錄?
1subject: [加密問題] gcin在終端機顯示的拆碼記錄?Promote 0 Bookmark 02008-03-18quote
老大好~
我用終端機執行gcin的時候,發現終端機出現我的拆碼記錄(如下,一堆「卜卜一口人田十口」的就是)
有時候讓人知道自己打了什麼字有點不太好,尤其是有關比較機密文件時
請問我有什麼方式可以為gcin加密嗎?
謝謝您
gcin get env LC_CTYPE=(null)  LC_ALL=zh_TW.UTF-8  LANG=zh_TW.UTF-8
~$-- /tmp/gcin-winlin/socket-:0.0-gcin
connection via TCP is disabled
gtab file /home/winlin/.gcin/cj.gtab.append.gtab
keybits:6
KeyS 43
all_full_ascii 95
 !(){}|~[]\:;',./abcdefghijklmnopqrstuvwxyz
inmdno: 1 th.KeyS:43
chars 13119
inp->phrnum: 5
(gcin.real:30994): Gtk-CRITICAL **: gtk_label_set_text: assertion `GTK_IS_LABEL (label)' failed
(gcin.real:30994): Gtk-CRITICAL **: gtk_widget_hide: assertion `GTK_IS_WIDGET (widget)' failed
key64: 0
卜卜卜卜卜一卜卜一口卜卜一口tsfname: /home/winlin/.gcin/tsin32
人人田人田十人田十口人田十口人人田人田十人田十口人田十口gtab file /usr/share/gcin/table/symbols.gtab
keybits:6
symbol kbm
KeyS 48
all_full_ascii 95
 `1234567890-=\[];',./abcdefghijklmnopqrstuvwxyz
inmdno: 4 th.KeyS:48
chars 47
inp->phrnum: 0
key64: 0
2subject: Promote 0 Bookmark 02008-03-18quote
gcin > /dev/null 2>&1 &
3subject: Promote 0 Bookmark 02008-03-18quote
感謝LGJ兄,那些拆碼已經都引向 /dev/null去了, OK~微笑
