enPV editor
freehand lines neon glow
1subject: freehand lines neon glowPromote 0 Bookmark 02017-06-13quote
freehand lines neon glowfreehand lines neon glow
2subject: Promote 0 Bookmark 02017-07-16quote
The 't' above look weird. You can use a text polygon with neon glow in this case. You can edit the control points if you want the irregular look of freehand.
  1. 多邊形區域選擇
  2. Text Outline
  3. enter t、size→OK
  4. Tap the rectange on the toolbar, the 't' is filled with color.
  5. Tap the 't'. ic_menu_edit.png is shown on the bottom-left. Tap it to edit the color and neon glow.
polygon neon glow
polygon neon glow
edited: 9
3subject: Promote 0 Bookmark 02018-03-08quote
freehand rainbow/star/heart strokes.  The star/heart can be replaced with any emoji symbol.
AndCamera freehand rainbow
edited: 7
4subject: Promote 0 Bookmark 02018-03-10quote
The outlines of script font have overlappings. The neon glow looks weird.
To generate merged outlines, check 'Script font merge' in the dialog of text outline generation.
neon glow text script font merge
edited: 6
enPV editor
