enPV editor
Use AndCamera photo editor to synthesize the background of 'shallow depth of field', black&white, spray
1subject: Use AndCamera photo editor to synthesize the background of 'shallow depth of field', black&white, sprayPromote 0 Bookmark 02018-01-10quote
'shallow depth of field': blurry background
  1. Tap多邊形區域選擇, tap 'Handcraft',draw the polygon selection of the object。Use 'Max zoom' to zoom in if necessary。Tap OK to connect the last edge of the polygon and complete the editing.
  2. While the poly is selected, tap 'photo filter'
  3. Tap Blur or Increamental Blur
Other effects: Grey, Spray, Pencil sketech, Mosaic, Wave
AndCamera photo editor 'shallow depth of field'AndCamera photo editor 'shallow depth of field' - original photophoto editor 'shallow depth of field' - Blurphoto editor 'shallow depth of field' - Incremental Blurphoto editor 'shallow depth of field' - black and white backgroundphoto editor 'shallow depth of field' - Spray backgroundphoto editor 'shallow depth of field' - pencil sketch backgroundphoto editor 'shallow depth of field' - wave backgroundAndCamera photo editor Pointillism filterAndCamera photo editor oil painting filterAndCamera photo editor diagonal filter
edited: 9
2subject: Promote 0 Bookmark 02017-04-01quote
The new 'Smooth' background has the watercolor painting effect.
Smooth background, watercolor painting effect
3subject: Promote 0 Bookmark 02017-05-27quote
Special effects generated by dark grow/shrink filters.
dark grow filterdark shrink filter
4subject: Promote 0 Bookmark 02017-04-09quote
Using heart ♥ or star★ as the background.
AndCamera photo editor,Heart ♥ as the backgroundAndCamera photo editor,star★ as the background
5subject: Promote 0 Bookmark 02017-04-16quote
AndCamera photo editor hexagon, honeycomb background
enPV editor
