enComputerevilvte
evilvte 0.4.6 released
1subject: evilvte 0.4.6 releasedPromote 1 Bookmark 02010-04-06quote
Changelog:
0.4.6
 * Apply a workaround for VTE 0.24.0 vte_terminal_set_background_image_file()
   bug
0.4.6~pre6
 * Support CURSOR_SHAPE
 * New BACKSPACE_KEY and DELETE_KEY option: ERASE_TTY
 * Make everything GSEAL_ENABLE compatible
   Further information: http://live.gnome.org/GnomeGoals/UseGseal
 * Simplify Makefile and configure
0.4.6~pre5
 * Saturation can be adjusted by holding Ctrl and scrolling mouse up or down.
   Define both MOUSE_CTRL_SATURATION and HOTKEY to TRUE to use this function.
   If CTRL_ALT is TRUE, you have to hold Ctrl and Alt while scrolling.
 * Remove close button border in some specific themes
   Thanks to Tetralet <tetralet AT gmail DOT com>
0.4.6~pre4
 * Support MATCH_STRING_EXEC
   You may click an URL to open it without menu
 * Fix an Arch Linux bug.
   When TAB_LABEL is not defined, move mouse cursor to tabbar will make evilvte
   crash.
   Fix this by defining TAB_LABEL when Arch Linux is detected.
   Thanks to Ethan.
 * Remove evilvte.xpm
0.4.6~pre3
 * Respect CC
   Switch auto-detect-SUSE from gcc to ld
 * Support gnome-default-applications
 * Support "make uninstall"
 * VTE_FIXED color style will be disabled if VTE version >= 0.17.1
 * Do not define SHOW_WINDOW_BORDER automatically
0.4.6~pre2
 * Support -d command line option to run as a dock
 * Support WINDOW_TITLE_DYNAMIC for xterm escape sequences, Thanks to IllvilJa
 * Support personal configuration file other than src/config.h. For example:
   "make distclean ; ./configure --config=/dev/null ; make strip"
 * Drop useless option SHOW_WINDOW_TITLE and LABEL_DIALOG_SATURATION
0.4.6~pre1
 * Support PROGRAM_ICON so users can put their own icons at $HOME
 * Respect CFLAGS and OPTFLAGS
 * Drop obsolete option "Select_all" in MENU_CUSTOM
   Please use "Select all" instead
 * Auto-detect GNU gold linker to avoid unnecessary libraries linking
 * Improve coloring of showvte and configure script
 * Improve man page description. Thanks to editors of http://freshmeat.net.
 * Drop environment variable EVILVTE=min
aragon
posted: 5
3subject: Promote 0 Bookmark 02010-04-13quote
Thank you for another nice evilvte release!
 A while ago I took over maintainership of the FreeBSD port.  I needed to patch some of your code to make it build correctly on FreeBSD, and I've attached the patch here for you to consider including in your source.
enComputerevilvte
