cht電腦資訊
Google 瀏覽器 Chrome
1subject: Google 瀏覽器 ChromePromote 0 Bookmark 12008-09-03quote
有人去下載來用過了嗎?不知道情形如何?目前好像只有 windows 版。
 Google 瀏覽器 Chrome
目前只找到一篇 blog 有提到:
 http://blog.gslin.org/archives/2008/09/03/1659/
2subject: Promote 0 Bookmark 02008-09-03quote
用 wine 1.1.3 可以在 Linux 下跑,但不堪用。
win32 下目前一般評價都不錯。
3subject: Promote 0 Bookmark 02008-09-03quote
google 連下了幾招重招,如果成功的話,這會不會代表,將來的 OS 只是「懶珊」的東西了?一切在 web 完成?
dou0228
posted: 21
promoted: 2
4subject: Promote 0 Bookmark 02008-09-03quote
有此可能, BIOS 都能用 Linux 開啟 browser + skype 了..吐舌頭
不過目前, Chrome 是採取一個 tab 就產生一個 process, 蠻吃 RAM 的
5subject: Promote 0 Bookmark 02008-09-03quote
據說,若想解除安裝的話,會出現這張圖。大笑
 http://www.flickr.com/photos/mlchen/2824555731/sizes/o/
我猜想,要和 firefox 拼的話會有 plug-in 瓶頸,現在的 firefox,不僅僅是 firefox,而是那一大堆的 plug-in。
6subject: Promote 0 Bookmark 02008-09-04quote
從 FreeBSD list 找到一些有趣的連結:
用 Chrome po 文章,版權會變成 google 的。:p
 http://www.theregister.co.uk/2008/09/03/google_chrome_eula_sucks/
 http://yro.slashdot.org/article.pl?sid=08/09/03/0247205&from=rss
安全性通報:
 Google Chrome Download Vulnerability
added September 3, 2008 at 01:52 pm
US-CERT is aware of a vulnerability that affects the Google Chrome web browser. This vulnerability is due to a default configuration that allows files to be downloaded without prompting the user. In addition, downloaded files can be opened with a single click, which could allow a user to inadvertently open a malicious file.
US-CERT encourages users to enable the "Ask where to save each file before downloading" option within the "Minor Tweaks" tab in the browser preferences. Although this does not fix the underlying vulnerability, selecting this option will warn the user before files are downloaded. Users should still exercise caution when visiting and downloading items from untrusted websites.
US-CERT will provide additional information as it becomes available.
7subject: Promote 0 Bookmark 02008-09-04quote
Google Chrome 在 Windows 下,以一個 beta 版來看,有這樣的成績實在是很不錯,但看到這條文,我想我還是繼續堅守 Fx 吧!
8subject: Promote 0 Bookmark 02008-09-04quote
那些條文應該是還會再修正,可能是不小心。
不過,據說,那個 BETA 其實是掛了好久了,有點故意掛的,好留個後步來改進又不致受太強烈的批評。:p
9subject: Promote 0 Bookmark 02008-09-04quote
應該是自動授權給 google。
10subject: Promote 0 Bookmark 02008-09-04quote
 google 的確喜歡把自己的 service 掛上 beta 字樣,常常已經推出很久、人家都覺得已經很不錯了, beta 字樣還是留著,但這次情形不太一樣啦,畢竟 chrome 是剛公開推出的產品,掛個 beta 應不為過。
 那些條文就 webservice 來說應還 ok,但就瀏覽器來說,就不太好了。
11subject: Promote 0 Bookmark 02008-09-04quote
 chrome 用的是 BSD license,應該給點掌聲! 啪啪啪……
  http://code.google.com/chromium/terms.html
12subject: Promote 0 Bookmark 02008-09-04quote
 MozTW 那邊 orange 提供資訊說:據說 EULA 已經改了。
 http://chinese.engadget.com/2008/09/03/update-google-chrome-eula-corrected/
13subject: Promote 0 Bookmark 02008-09-04quote
應該是自動授權給 google。
是的,原文是 `Your copyright go up in smoke'。應該是說「你的版權雲消霧散」比較正確。不過,如果連出版權也給拿去了,那真還的是「雲消霧散」了!微笑
一般的網站都會有「在地」(in the place)使用權的條款,這個無可厚非,但連出版相關的權利也要送人,這個就說不過去了。但 google 那邊已經做出修正,我引的第一個 url 也修改了 po 文!
Your copyright does not now go up in smoke
11.1 You retain copyright and any other rights that you already hold in Content that you submit, post or display on or through the Services.
裡頭的內容已經修改了。看來群眾及媒體的力量是無遠弗屆的呀!大笑
14subject: Promote 0 Bookmark 02008-09-07quote
這是指 chromium 吧?chrome 和 chromium 是不一樣的版本嗎?
開始有人在報導相關影響了:
Google Chrome新瀏覽器即將掀起的的7大巨浪
不過,據說美國反托拉斯相關人員已經開始盯上 google 了。:)
15subject: Promote 0 Bookmark 02008-09-08quote
 Chromium 的官網上寫著: Chromium is the open-source project behind Google Chrome.
 又因 Chromium 是 BSD,所以即使 Chrome 不改 EULA,我們仍可由 Chromium 編譯出不受 EULA 限制的 chrome browser?
cht電腦資訊
