enComputerevilvte
Few ideas for new versions
1subject: Few ideas for new versionsPromote 0 Bookmark 02008-07-15quote
Hi.
I'm using mrxvt for more than one year. It's great terminal emulator, but has problem with xft font encoding. Today I've found evilvte. Small, quite fast [but starts a bit longer than mrxvt] and with great feature - encoding change. Tried to switch to evilvte, but couldn't - few options are missing, and I've decided to stay with mrxvt.
So I've thought, I'll write down those few ideas, which might help improving evil and maybe some day it will be the best small emulator available.
1. Fullscreen toggle [menu] and fullscreen shortucut - terminal on whole screen, above panels.
2. As option: transparent tabs, matching terminal background - like mrxvt.
3. As option: Defining RGB values for each font color, for example when I have blue background [colors 4 and 12], I want to change a bit shade of blue to make it more visible.
4. As option: Off-focus fading - a bit darker fonts & background when terminal is out of focus.
5. As option: Close buttons on each tab.
I hope this will help make evilvte better. Keep up the good work :)
2subject: Few ideas for new versionsPromote 0 Bookmark 02008-07-16quote
Thank you! I will put them to TODO list.
Is it transparent tabbar? I will suppport it in next release.
I will suppport them in next release. Smile
3subject: Few ideas for new versionsPromote 0 Bookmark 02008-07-16quote
Great you'll add those things :)
Yes, it is. Looks like above. Also please notice two things:
1. Dashed lines around title,  to notice user about new output in third tab.
2. Dynamic tab title, chaning accoring to running application, differect working directory, etc.
4subject: Few ideas for new versionsPromote 0 Bookmark 02008-07-17quote
It is hard to use "dashed lines" in GTK+. I think a color change in tab label is good. (already in my TODO list)
It is already in my TODO list.
You may want to try lilyterm, which has supportted this feature. Smile
5subject: Promote 0 Bookmark 02008-07-18quote
Thanks for the link, but lily doesn't support fake transparency [background image]. And for me that's major functionality.
enComputerevilvte
