enComputerLilyTerm
LilyTerm 0.9.5 is released, Supports 'Hyperlink'!
Tetralet
posted: 255
promoted: 35
bookmarked: 13
1subject: LilyTerm 0.9.5 is released, Supports 'Hyperlink'!Promote 0 Bookmark 02008-07-09quote
2008/7/10 (0.9.5)
ChangeLog:
  • FIX:
    • Better compatibility with -e command line option.
  • New Feature:
    • Applied updated German translation. VERY THANKS to Mario Blättermann.
    • Hyperlink support. You may specify the command used for the hyperlink via edit the profile.
      You may use <Ctrl><`> to disable it for temporarily.
      You may disable it by setting `enable_hyperlink = 0' in profile.
    • Disable font anti-alias via setting `font_anti_alias = 2' in profile.
    • Make the tab to fill the tab bar via setting `fill_tab_bar = 1' in profile.
    • Use `tabbar_position = 1' to move the tab bar to the bottom of window.
    • Use `scrollbar_position = 2' to place the scroll bar on the right of vte terminal.
      Using `scrollbar_position = 0' to don't use scroll bar.
    • You may specify the font/window resize ratio by editing the `font_resize_ratio' and `window_resize_ratio' in profile.
    • Support audible_bell by default.
enComputerLilyTerm
