nvidia driver 的 bug ?
1subject: nvidia driver 的 bug ?Promote 0 Bookmark 02008-06-28quote
console 發出逼 聲後就當了,是 nvidia driver 的 bug 嗎? 網路似乎還是活的
VGA compatible controller: nVidia Corporation NV43 [GeForce 6600] (rev a2)
Jun 28 11:21:27 www kernel: irq 11: nobody cared (try booting with the "irqpoll" option)
Jun 28 11:21:27 www kernel: Pid: 28932, comm: X Tainted: P        2.6.24.my #2
Jun 28 11:21:27 www kernel:  [<c0148364>] __report_bad_irq+0x24/0x80
Jun 28 11:21:27 www kernel:  [<c01485df>] note_interrupt+0x21f/0x250
Jun 28 11:21:27 www kernel:  [<c0147a25>] handle_IRQ_event+0x25/0x60
Jun 28 11:21:27 www kernel:  [<c0148ee7>] handle_level_irq+0x57/0xa0
Jun 28 11:21:27 www kernel:  [<c0105a1b>] do_IRQ+0x3b/0x70
Jun 28 11:21:27 www kernel:  [<c01316e0>] tick_program_event+0x40/0x60
Jun 28 11:21:27 www kernel:  [<c01041bb>] common_interrupt+0x23/0x28
Jun 28 11:21:27 www kernel:  [<c011c620>] __do_softirq+0x30/0x90
Jun 28 11:21:27 www kernel:  [<c011c6a7>] do_softirq+0x27/0x30
Jun 28 11:21:27 www kernel:  [<c011c97a>] irq_exit+0x5a/0x60
Jun 28 11:21:27 www kernel:  [<c0105a20>] do_IRQ+0x40/0x70
Jun 28 11:21:27 www kernel:  [<f994df75>] _nv004364rm+0x59/0x70 [nvidia]
Jun 28 11:21:27 www kernel:  [<f994dff1>] _nv004362rm+0x28/0x43 [nvidia]
Jun 28 11:21:27 www kernel:  [<f994e049>] _nv004372rm+0x37/0x41 [nvidia]
Jun 28 11:21:27 www kernel:  [<f99cd11b>] _nv001595rm+0xf/0x2a [nvidia]
Jun 28 11:21:27 www kernel:  [<f9922f34>] _nv008202rm+0xe7/0x10e [nvidia]
Jun 28 11:21:27 www kernel:  [<f991ae64>] _nv010405rm+0x3d/0x173 [nvidia]
Jun 28 11:21:27 www kernel:  [<f98bb4e1>] _nv004457rm+0x2a/0x144 [nvidia]
Jun 28 11:21:27 www kernel:  [<f98ba794>] _nv004461rm+0x12a/0x3c9 [nvidia]
Jun 28 11:21:27 www kernel:  [<f98bab04>] _nv004454rm+0x8b/0x92 [nvidia]
Jun 28 11:21:27 www kernel:  [<f99020dc>] _nv003024rm+0xa6/0xb4 [nvidia]
Jun 28 11:21:27 www kernel:  [<f9901ff6>] _nv003020rm+0x1c2/0x202 [nvidia]
Jun 28 11:21:27 www kernel:  [<f9900ac2>] _nv003039rm+0x17f/0x2e1 [nvidia]
Jun 28 11:21:27 www kernel:  [<f98fcf60>] _nv005240rm+0x4e/0x75 [nvidia]
Jun 28 11:21:27 www kernel:  [<f97c288d>] _nv002985rm+0x195/0x5fd [nvidia]
Jun 28 11:21:27 www kernel:  [<f9965fed>] rm_ioctl+0x3e/0x6d [nvidia]
Jun 28 11:21:27 www kernel:  [<f9a0aa76>] nv_kern_ioctl+0x116/0x3b0 [nvidia]
Jun 28 11:21:27 www kernel:  [<f9a0ad48>] nv_kern_unlocked_ioctl+0x18/0x20 [nvidia]
Jun 28 11:21:27 www kernel:  [<f9a0ad30>] nv_kern_unlocked_ioctl+0x0/0x20 [nvidia]
Jun 28 11:21:27 www kernel:  [<c0177a9f>] do_ioctl+0x1f/0x70
Jun 28 11:21:27 www kernel:  [<c015c8be>] do_munmap+0x18e/0x1f0
Jun 28 11:21:27 www kernel:  [<c0177cce>] vfs_ioctl+0x1de/0x270
Jun 28 11:21:27 www kernel:  [<c0177db6>] sys_ioctl+0x56/0x70
Jun 28 11:21:27 www kernel:  [<c0103fce>] sysenter_past_esp+0x5f/0x85
Jun 28 11:21:27 www kernel:  [<c0104629>] show_trace_log_lvl+0x9/0x30
Jun 28 11:21:27 www kernel:  =======================
2subject: Promote 0 Bookmark 02008-06-28quote
我遇過多次了,是不是有重編譯 kernel,但 nvidia driver 卻沒重編譯過?
3subject: Promote 0 Bookmark 02008-06-28quote
在 linux 有 compile kernel,nvidia driver 是不可能 load 進去的
4subject: Promote 0 Bookmark 02008-06-28quote
Soga,在 FreeBSD 是能夠使用舊的 driver,但很容易就當掉。Linux 的情形忘得差不多了。:p
