gcin 1.4 linux 64 無法正確運作
1subject: gcin 1.4 linux 64 無法正確運作Promote 0 Bookmark 02008-05-28quote
我使用 archlinux,以下列方式產生 gcin
     cd $startdir/src/$pkgname-$pkgver
    ./configure --prefix=/usr
    make || return 1
    make prefix=$startdir/pkg/usr \
         datadir=$startdir/pkg/usr/share \
         bindir=$startdir/pkg/usr/bin \
         libdir=$startdir/pkg/usr/lib \
         includedir=$startdir/pkg/usr/include \
         man1dir=$startdir/pkg/usr/man/man1 \
        install
發現 必須先 cd /usr/lib/gcin 才能執行 gcin
不然會找不到  gcin 的 library.
3subject: Promote 0 Bookmark 02008-05-28quote
The error message is:
  gcin: error while loading shared libraries: gcin1.so: cannot open shared object file: No such file or directory
it works on linux 32 system. But can not work on linux 64 bit
I think this is caused by  configure file or loading lib algorithm.
Or, do you know what *.c file is related to this problem?
I've already contact the archlinux's package maintainer, but as you see, there is nothing special configure as my previous post.
4subject: Promote 0 Bookmark 02008-05-28quote
會不會 /usr/lib   /usr/lib64 的問題
6subject: Promote 0 Bookmark 02008-05-28quote
不是這樣的, archlinux 64 bit 上只有一個 /usr/lib 目錄.
7subject: Promote 0 Bookmark 02008-05-28quote
看一下
可能 LD_RUN_PATH 有錯 ?
$ldd /usr/local/bin/gcin
        linux-gate.so.1 =>  (0xb7fe4000)
        gcin1.so => /usr/local/lib/gcin/gcin1.so (0xb7fd9000)
        gcin2.so => /usr/local/lib/gcin/gcin2.so (0xb7fd7000)
8subject: Promote 0 Bookmark 02008-05-28quote
ldd `which gcin`
    linux-vdso.so.1 =>  (0x00007fff413fe000)
    gcin1.so => not found
    gcin2.so => not found
 請問這要怎麼設呢? 要怎麼讓package maintainer可以包裝好呢?
9subject: Promote 0 Bookmark 02008-05-28quote
gcin1.so 的 path 是由  LD_RUN_PATH 指定
如果弄不出來,可以考慮不要拆成 .so
Makefile
gcin:   $(OBJS) $(IMdkitLIB) $(im-srv)
        LD_RUN_PATH=.:$(gcinlibdir) \
        $(CC) $(EXTRA_LDFLAGS) -o $@ $(OBJS) $(IMdkitLIB) $(im-srv) -lXtst $(LDFLAGS) -L/usr/X11R6/lib
10subject: Promote 0 Bookmark 02008-05-28quote
我想應該是這一行的指定在 configure 時沒效.
我看到  config.mak 裏面
   libdir=$(DESTDIR)/usr/lib64
但還是不知道改怎麼修正.(難道是要 report 給 autoconf 作者?)
11subject: Promote 0 Bookmark 02008-05-28quote
gcin 是用手工打造的 script 與 autoconf 無關
12subject: Promote 0 Bookmark 02008-05-29quote
難道不是
./configure
產生的  libdir=$(DESTDIR)/usr/lib64 嗎?
13subject: Arch64 gcin canPromote 0 Bookmark 02008-06-20quote
我找到問題, 但是, 這需要 gcin 作者修改. 測過 1.4.1 仍有此問題.
 即 -
參考 http://bugs.archlinux.org/task/7225
在 configure 過後,
手工修改 config.mak
變成
 因為我不懂 autoconf, 不知道底要改那裡才對.
主要原因是作者假設 arch 64 系統依定會有 /usr/lib64 目錄, 但是 ArchLinux x86_64 底下, 標榜只放純 64 bit 程式, 所以沒有那個目錄.
只有 /usr/lib, 另外, 要額外裝才有 /usr/lib32
dlin
posted: 11
15subject: Arch64 gcin canPromote 0 Bookmark 02008-06-20quote
This is not upstream author's problem.
This is package maintainer's problem.
這應該是 gcin 作者要調整的, autoconf 就是要能夠適應各種環境.
因為設定的好, confingure 就應該能引用 /usr/lib/gcin, 而非 /usr/lib64/gcin 才對.
dlin
posted: 11
17subject: Promote 0 Bookmark 02008-06-20quote
不好意思.
我手動下 ./configure 時出現
 testing if you have QT_IM_MODULE dir:/usr/lib/qt4/plugins/lib64/inputmethods support
請問這是不是我少裝什麼呢? 還是並不一定需要. 我有裝 qt4.
我大概知道問題出在那 configure script
LIB='lib'
if [ -d /lib64 ]; then
LIB='lib64'
fi
因為 archlinux 也有 /lib64 目的是為了一些 binary distribution package 用. 所以
LIB=lib64
而最後
 libdir=$(DESTDIR)/usr/local/lib64
並非 archlinux 想要用的
我再去找 archlinux package maintainer 問問看... 謝啦!
swyear
posted: 127
promoted: 4
19subject: Promote 0 Bookmark 02008-06-20quote
舉例說明
在 openSUSE qt3 inputmethods 目錄在
/usr/lib64/qt3/plugins/inputmethods
而非像 mandrava 在
/usr/lib/qt3/plugins/lib64/inputmethods
所以就自己改以符合發行版本的特性就好了
 --- configure.orig    2007-07-10 11:22:51.000000000 +0800
+++ configure    2007-08-29 00:52:07.000000000 +0800
@@ -114,7 +114,7 @@
 QT_IM='N'
 for i in qt3 qt4
 do
-  QT_IM_DIR=/usr/lib/$i/plugins/$LIB/inputmethods
+  QT_IM_DIR=/usr/$LIB/$i/plugins/inputmethods
   echo "testing if you have QT_IM_MODULE dir:$QT_IM_DIR support"
   if [ -d  $QT_IM_DIR ]; then
     QT_IM='Y'
20subject: Promote 0 Bookmark 02008-06-20quote
dlin
LIB=lib64
而最後
並非 archlinux 想要用的
把 configure 以下的判斷式註解起來就行了:
#if [ -d /lib64 ]; then
#LIB='lib64'
#fi
