enComputerLilyTerm
LilyTerm 0.8.9 is released. Opacity window is supported!
Tetralet
posted: 255
promoted: 35
bookmarked: 13
1subject: LilyTerm 0.8.9 is released. Opacity window is supported!Promote 0 Bookmark 02008-05-01quote
2008/5/1 (0.8.9)
ChangeLog:
  • FIX:
    • rgba won't be enabled by default if the screen is composited.
    • Better compatibility when the font rendering / theme changed too fast.
  • New Feature:
    • Window opacity is supported, and it will enabled by default if the screen is composited.
      You may use `window_opacity = 0.15' in your profile to specify the opacity.
      You may use `transparent_window = 0' in your profile to disable it.
    • May use `show_transparent_menu = 0' to disable transparent/opacity menu items.
    • New menu item: [Transparent Window] and [Window Opacity].
enComputerLilyTerm
