enComputerLilyTerm
LilyTerm 0.8.5 released. Supports to show the foreground running command on tab/window!
Tetralet
posted: 255
promoted: 35
bookmarked: 13
1subject: LilyTerm 0.8.5 released. Supports to show the foreground running command on tab/window!Promote 1 Bookmark 02008-04-13quote
2008/4/12 (0.8.5) (Source Code) (Debian Lenny Package) (Ubuntu Gutsy Package)
  • FIX:
    • The serial no of the the tab will shown when reorder the tab even if page_names_no=0.
    • Use <Ctrl><O> to select all the text in vte box. <Ctrl><S> is used in rtorrent to start a torrent download.
    • The size of vtebox now won't be changed if the GNOME themes changed.
  • New Feature:
    • Reuse the page names. It can been disabled by reuse_page_names = 0 in the profile.
    • Shows the foreground running command on tab. It can been disabled by page_shows_current_cmdline = 0 in the profile.
    • Shows the foreground running command on window title. It can been disabled by window_shows_current_page = 0 in the profile.
    • Confirm to close a tab if there was a foreground running application.
    • Use kill() to kill running shell when use <Ctrl><W> or <Alt><F4> to force close this tab. Or the sub-process of this tab will be closed at the same time.
      NOTE: please use <Ctrl><D> or exit to close tabs. <Ctrl><W> and <Alt><F4> only used when the foreground program of this tab is no-responds. the foreground program will be close if you pressed <Ctrl><W> to close this tab.
    • New menu item: [Change the font of every tab].
Tetralet
posted: 255
promoted: 35
bookmarked: 13
2subject: The LilyTerm main server was down for temporaryPromote 0 Bookmark 02008-04-13quote
The Luna server was down for temporary. Please download the append file instead.
enComputerLilyTerm
