cht電腦資訊LilyTerm
多分頁狀態下關閉第一個分頁導致lilyterm整個關閉
Solomon
posted: 78
promoted: 22
1subject: 多分頁狀態下關閉第一個分頁導致lilyterm整個關閉Promote 0 Bookmark 02008-04-05quote
版本0.8.3
不管開幾個分頁。只要第一次開始的分頁被關掉,lilyterm就被終結了。
Tetralet
posted: 255
promoted: 35
bookmarked: 13
2subject: Promote 0 Bookmark 02008-04-06quote
不知耶?請試試新版 LilyTerm 看看是不是有相同問題?
Solomon
posted: 78
promoted: 22
3subject: Promote 0 Bookmark 02008-04-06quote
0.8.4 一樣會發生唷。
附上操作影片。
Tetralet
posted: 255
promoted: 35
bookmarked: 13
4subject: Promote 0 Bookmark 02008-04-06quote
好怪...
請問操作環境?Gtk+2 的版本?是自行編譯的嗎? 是 Segmentation fault 錯誤嗎?還是有其它錯誤訊息?
Solomon
posted: 78
promoted: 22
5subject: Promote 0 Bookmark 02008-04-06quote
我用的是 lenny,沒有自己編過。
ii  libgtk2.0-0               2.12.9-2                  The GTK+ graphical user interface library
ii  libgtk2.0-bin             2.12.9-2                  The programs for the GTK+ graphical user interface library
ii  libgtk2.0-common          2.12.9-2                  Common files for the GTK+ graphical user interface library
ii  libvte-common             1:0.16.13-1               Terminal emulator widget for GTK+ 2.0 - common files
un  libvte2                   <無>                     (無相關介紹)
rc  libvte4                   1:0.12.2-5                Terminal emulator widget for GTK+ 2.0 - runtime files
ii  libvte9                   1:0.16.13-1.im            Terminal emulator widget for GTK+ 2.0 - runtime files
我直接在 lilyterm 中執行另一個 lilyterm,並執行影片中的步驟。當 parent  的 lilyterm 中沒有顯示任何的訊息,看起來就像是正常的結束。
Tetralet
posted: 255
promoted: 35
bookmarked: 13
6subject: Promote 0 Bookmark 02008-04-06quote
看不出來是哪裡出錯...
gint total_page = gtk_notebook_get_n_pages(GTK_NOTEBOOK(notebook));
// if it is the last page, exit application!
if (total_page == 1)
        gtk_main_quit();
我猜是上面這段程式碼關掉 LilyTerm 的。但沒道理在那麼多分頁下,total_page 會等於 1 呀?
我再試一下好了。
7subject: Promote 0 Bookmark 02008-04-06quote
教使用者用 gdb debug coredump 的地方
Solomon
posted: 78
promoted: 22
8subject: Promote 0 Bookmark 02008-04-07quote
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xb749e720 (LWP 10284)]
0xb4257385 in ?? ()
(gdb) bt
#0  0xb4257385 in ?? ()
#1  0xb77ebeca in g_cclosure_marshal_VOID__OBJECT ()
   from /usr/lib/libgobject-2.0.so.0
#2  0xb77df6f9 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#3  0xb77f3c3d in ?? () from /usr/lib/libgobject-2.0.so.0
#4  0x0829cf60 in ?? ()
#5  0x00000000 in ?? ()
(gdb)
這個是 deb 的執行檔使用 gdb 的結果。
但是我抓 source 回來編,不會有這樣的情況發生。 @@
9subject: Promote 0 Bookmark 02008-04-07quote
如果 compile -g -O 看看。這樣只會顯示 function name,沒有 line nmber
Solomon
posted: 78
promoted: 22
10subject: Promote 0 Bookmark 02008-04-07quote
可能要請 Tetralet 兄丟一個 binary 給我,因為我自已 compile 出來的不會。
Silice
posted: 306
promoted: 47
bookmarked: 17
11subject: Promote 0 Bookmark 02008-04-09quote
敝人安裝新版後也有這個問題
把~/.config/lilyterm.rc換成最近的設定檔範例後就不會有這個問題了
新的設定檔範例裡多了這三行
page_names = Terminal
page_number = 1
show_input_method_menu = 0
Silice
posted: 306
promoted: 47
bookmarked: 17
12subject: Promote 0 Bookmark 02008-04-09quote
經敝人測試
 font_name = monospace 15
請設成15(設成13、14、16)就會發生這個問題
這是敝人的 ~/.fonts.conf
 <match target="pattern" >
        <test compare="eq" name="family" >
                <string>monospace</string>
        </test>
        <edit mode="assign" binding="strong" name="family" >
                <string>DejaVu Sans Mono</string>
                <string>Firefly New Sung</string>
        </edit>
</match>
Tetralet
posted: 255
promoted: 35
bookmarked: 13
13subject: Promote 0 Bookmark 02008-04-09quote
我移掉設定檔和 ~/.fonts.conf 後,測試了幾個 vte based 程式,像是 LilyTerm, evilvte, termit, roxterm,都會當:
[Switching to Thread 0xb73d8720 (LWP 19327)]
0xb1e33385 in ?? ()
(gdb) bt
#0  0xb1e33385 in ?? ()
#1  0xb79e6eca in g_cclosure_marshal_VOID__OBJECT () from /usr/lib/libgobject-2.0.so.0
#2  0xb79da6f9 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#3  0xb79eec3d in ?? () from /usr/lib/libgobject-2.0.so.0
#4  0x082e2858 in ?? ()
我是當在以下這一行:
gtk_notebook_remove_page(GTK_NOTEBOOK(notebook), current_page_no);
看來是 gtkNotebook 有問題?因為  xfce4-terminal 意外的不會當,因為它不用 gtkNotebook。看來這個問題除非去 debug gtk+2.0,否則暫時是無解了。
cht電腦資訊LilyTerm
