enComputerevilvte
evilvte 0.3.4 released
1subject: evilvte 0.3.4 releasedPromote 0 Bookmark 02008-03-28quote
Changelog:
 * Support MENU_MATCH_STRING_EXEC
   You can right click to open an URL now.
 * Support "Select font" item in menu
 * Support CTRL_FONT_SELECT
 * Fix a bug when FONT_SIZE is defined without defining FONT
 * Support PROGRAM_VERSION for personal versioning
 * Simplify menu customization
 * Remove DOUBLE_PRESS_HOTKEY because its function can be replaced by menu
 * Remove DEFAULT_FONT_SIMPLE and MENU_ENCODING_DEFAULT for a more readable
   config file
2subject: Promote 0 Bookmark 02008-03-29quote
請問 configure 時出現
Package vte was not found in the pkg-config search path.
Perhaps you should add the directory containing `vte.pc'
to the PKG_CONFIG_PATH environment variable
No package 'vte' found
可是系統上已有 libvte-common, 還缺什麼才能進行 configure ?
3subject: Promote 0 Bookmark 02008-03-29quote
要安裝 libvte-dev* 之類的套件才能編譯。
enComputerevilvte
