enComputerevilvte
evilvte 0.3.1 released
1subject: evilvte 0.3.1 releasedPromote 0 Bookmark 02008-03-24quote
Changelog:
 * Fix an openSUSE 10.3 KDE bug.
   When TAB_LABEL is not defined, move mouse cursor to tabbar will make evilvte
   crash.
   Fix this by defining TAB_LABEL when SUSE system is detected.
 * Support MENU_CUSTOM
 * Support MENU_RESET, MENU_QUIT, and MENU_SEPARATOR_*
swyear
posted: 127
promoted: 4
2subject: Promote 0 Bookmark 02008-03-24quote
when build on openSUSE Build Serice,
SUSE_DETECTED will be "FALSE", because the file /etc/SuSE-release in not exist.
In OBS, the package " openSUSE-release" which contains the file /etc/SuSE-release
will not be installed by default.
I do it manually by passing the env var SUSE_DETECTED="TRUE" to make,
works fine too.
Thank you very much.
swyear
posted: 127
promoted: 4
4subject: Promote 0 Bookmark 02008-03-24quote
build log
enComputerevilvte
