fedora 28 用不到 GCIN
edwardyu
posted: 10
香港
1subject: fedora 28 用不到 GCIN Promote 0 Bookmark 02018-05-03quote
fedora 28 usb live 可以boot起。但gcin用不到,conflict with ibus。如dnf erase ibus後,整過fedora 28 hang機   ! 都是用回fedora 27 好了。
edwardyu
posted: 10
香港
2subject: fedora 28 用不到 GCIN - 錯誤訊息Promote 0 Bookmark 02018-05-04quote
我是根據老刀兄的方法安裝的: https://fedora-tw.org/t/fedora-21-workstation-gcin-fedora-22-23/29
#dnf install gcin*
結果:成功。gcin 版本是gcin.i686 2.8.5-4.fc28
#reboot
$im-chooser
結果:command not found, but ask to install.
install im-chooser-1.7.1-4.fc28.i386 成功
but popup screen : No INput Method
                            Use iBus (recommended)
#gcin
結果:IMOpenIM 'ibus' failed. Maybe another XIM server is running
$gsettings set org.gnome.settings-daemon.plugins.keyboard active false
結果:No such schema "org.gnome.settings-daemon.plugins.keyboard"
我dnf erase ibus 之後boot 不起fedora 28。要用usb live重裝。
edwardyu
posted: 10
香港
3subject: Promote 0 Bookmark 02018-05-04quote
Just find a bug report: keyboard plugin cannot be disabled so we cannot use any other input method than ibus
https://gitlab.gnome.org/....../gnome....../issues/25
4subject: Promote 0 Bookmark 02018-05-04quote
Thanks.
