ctrl + space 會讓 gcin 重新啟動
maxwux
posted: 28
1subject: ctrl + space 會讓 gcin 重新啟動Promote 0 Bookmark 02013-10-29quote
我用 linux mint 15
最近有更新 gcin 到 2.8.1
是透過 deb http://cle.linux.org.tw/gcin/download/debian eliu release 來更新的
更新後 gcin 只要在 en  模式下按下 ctrl+space 就會重新啟動 gcin
而不是切換成詞音
如果先按下 ctrl+alt+6 之後再切換 en 或者詞音就沒有問題
不知道是什麼地方有問題?
export PERL_LOCAL_LIB_ROOT="$PERL_LOCAL_LIB_ROOT:~/perl5";
export PERL_MB_OPT="--install_base ~/perl5";
export PERL_MM_OPT="INSTALL_BASE=~/perl5";
export PERL5LIB="~/perl5/lib/perl5:$PERL5LIB";
export PATH="/sbin:/usr/sbin:~/perl5/bin:$PATH";
export GTK_PATH="/usr/lib64/gtk-2.0/immodules/im-gcin.so";
export GTK_IM_MODULE=gcin
export LC_CTYPE=zh_TW.UTF-8
$ /usr/lib/x86_64-linux-gnu/libgtk2.0-0/gtk-query-immodules-2.0
# GTK+ Input Method Modules file
# Automatically generated file, do not edit
# Created by /usr/lib/x86_64-linux-gnu/libgtk2.0-0/gtk-query-immodules-2.0 from gtk+-2.24.17
# ModulesPath = /usr/lib64/gtk-2.0/immodules/im-gcin.so/2.10.0/x86_64-pc-linux-gnu/immodules:/usr/lib64/gtk-2.0/immodules/im-gcin.so/2.10.0/immodules:/usr/lib64/gtk-2.0/immodules/im-gcin.so/x86_64-pc-linux-gnu/immodules:/usr/lib64/gtk-2.0/immodules/im-gcin.so/immodules:~/.gtk-2.0/2.10.0/x86_64-pc-linux-gnu/immodules:~/.gtk-2.0/2.10.0/immodules:~/.gtk-2.0/x86_64-pc-linux-gnu/immodules:~/.gtk-2.0/immodules:/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/x86_64-pc-linux-gnu/immodules:/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules:/usr/lib/x86_64-linux-gnu/gtk-2.0/x86_64-pc-linux-gnu/immodules:/usr/lib/x86_64-linux-gnu/gtk-2.0/immodules:/usr/lib/gtk-2.0/2.10.0/x86_64-pc-linux-gnu/immodules:/usr/lib/gtk-2.0/2.10.0/immodules:/usr/lib/gtk-2.0/x86_64-pc-linux-gnu/immodules:/usr/lib/gtk-2.0/immodules
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-multipress.so"
"multipress" "Multipress" "gtk20" "" ""
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-ti-er.so"
"ti_er" "Tigrigna-Eritrean (EZ+)" "gtk20" "/usr/share/locale" "ti"
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-xim.so"
"xim" "X Input Method" "gtk20" "/usr/share/locale" "ko:ja:th:zh"
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-cedilla.so"
"cedilla" "Cedilla" "gtk20" "/usr/share/locale" "az:ca:co:fr:gv:oc:pt:sq:tr:wa"
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-cyrillic-translit.so"
"cyrillic_translit" "Cyrillic (Transliterated)" "gtk20" "/usr/share/locale" ""
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-am-et.so"
"am_et" "Amharic (EZ+)" "gtk20" "/usr/share/locale" "am"
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-thai.so"
"thai" "Thai-Lao" "gtk20" "/usr/share/locale" "lo:th"
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-ti-et.so"
"ti_et" "Tigrigna-Ethiopian (EZ+)" "gtk20" "/usr/share/locale" "ti"
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-inuktitut.so"
"inuktitut" "Inuktitut (Transliterated)" "gtk20" "/usr/share/locale" "iu"
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-viqr.so"
"viqr" "Vietnamese (VIQR)" "gtk20" "/usr/share/locale" ""
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-ipa.so"
"ipa" "IPA" "gtk20" "/usr/share/locale" ""
"/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-gcin.so"
2subject: Promote 0 Bookmark 02013-10-29quote
懷疑內定的輸入法可能有問題。
先試試用 gcin-tools 更改內定輸入法到詞音。
再不行,mv .gcin gcin-old 試試看
maxwux
posted: 28
3subject: Promote 0 Bookmark 02013-10-29quote
eliu 太感謝你了,真的是 .gcin 壞掉了
重建之後就好了
感謝
