gcin打字固定在左上角,好像跟之前不太一樣
maxwux
posted: 28
1subject: gcin打字固定在左上角,好像跟之前不太一樣Promote 0 Bookmark 02013-04-10quote
這次的左上角問題有一點奇怪
在firefox, chrome中正常
但是在kate、vlc、smplayer、skype、kickoff、system setting都會固定在該程式視窗的左上角
好像不限定是gtk還是qt程式都有這個問題
我是用Chakra,桌面環境是KDE
有用過打包者的package
也用過source code自己compile
狀況都一樣
KDE版本是4.10.2
gcin 2.8.0
$ gtk-query-immodules-2.0
# GTK+ Input Method Modules file
# Automatically generated file, do not edit
# Created by gtk-query-immodules-2.0 from gtk+-2.24.15
# ModulesPath = /home/maxwux/.gtk-2.0/2.10.0/x86_64-unknown-linux-gnu/immodules:/home/maxwux/.gtk-2.0/2.10.0/immodules:/home/maxwux/.gtk-2.0/x86_64-unknown-linux-gnu/immodules:/home/maxwux/.gtk-2.0/immodules:/usr/lib/gtk-2.0/2.10.0/x86_64-unknown-linux-gnu/immodules:/usr/lib/gtk-2.0/2.10.0/immodules:/usr/lib/gtk-2.0/x86_64-unknown-linux-gnu/immodules:/usr/lib/gtk-2.0/immodules
"/usr/lib/gtk-2.0/2.10.0/immodules/im-viqr.so"
"viqr" "Vietnamese (VIQR)" "gtk20" "/usr/share/locale" "vi"
"/usr/lib/gtk-2.0/2.10.0/immodules/im-ti-er.so"
"ti_er" "Tigrigna-Eritrean (EZ+)" "gtk20" "/usr/share/locale" "ti"
"/usr/lib/gtk-2.0/2.10.0/immodules/im-inuktitut.so"
"inuktitut" "Inuktitut (Transliterated)" "gtk20" "/usr/share/locale" "iu"
"/usr/lib/gtk-2.0/2.10.0/immodules/im-xim.so"
"xim" "X Input Method" "gtk20" "/usr/share/locale" "ko:ja:th:zh"
"/usr/lib/gtk-2.0/2.10.0/immodules/im-multipress.so"
"multipress" "Multipress" "gtk20" "" ""
"/usr/lib/gtk-2.0/2.10.0/immodules/im-ipa.so"
"ipa" "IPA" "gtk20" "/usr/share/locale" ""
"/usr/lib/gtk-2.0/2.10.0/immodules/im-cyrillic-translit.so"
"cyrillic_translit" "Cyrillic (Transliterated)" "gtk20" "/usr/share/locale" ""
"/usr/lib/gtk-2.0/2.10.0/immodules/im-thai.so"
"thai" "Thai-Lao" "gtk20" "/usr/share/locale" "lo:th"
"/usr/lib/gtk-2.0/2.10.0/immodules/im-ti-et.so"
"ti_et" "Tigrigna-Ethiopian (EZ+)" "gtk20" "/usr/share/locale" "ti"
"/usr/lib/gtk-2.0/2.10.0/immodules/im-am-et.so"
"am_et" "Amharic (EZ+)" "gtk20" "/usr/share/locale" "am"
"/usr/lib/gtk-2.0/2.10.0/immodules/im-cedilla.so"
"cedilla" "Cedilla" "gtk20" "/usr/share/locale" "az:ca:co:fr:gv:oc:pt:sq:tr:wa"
不知道這個問題該怎麼解決??
2subject: Promote 0 Bookmark 02013-04-10quote
或許與 32, 64-bit path 有關,
用 lsof -p 看 AP 是否有 load im-gcin.so
maxwux
posted: 28
3subject: Promote 0 Bookmark 02013-04-11quote
lsof -p <gcin pid> 之後沒有出現im-gcin.so
我發現沒有 /usr/lib32/gtk-2.0/immodules/
但是有 /usr/lib/gtk-2.0/immodules/和 /usr/lib64/gtk-2.0/immodules/
裏面都有im-gcin.so就只有lib32裏面沒有im-gcin.so
我試過把lib64裏面的im-gcin.so給複製到lib32裏面,不過狀況仍舊相同
我該怎麼把這個檔案compile出來呢?
hyslion
posted: 36
promoted: 2
4subject: Promote 0 Bookmark 02013-04-11quote
maxwux
應該是
lsof -p <要用到輸入法的軟體的pid> | grep im-gcin.so
例如:lsof `pidof kwrite` | grep im-gcin.so
64和32的so不能混用,而且我覺得問題應該不在32位元跟64位元上。
另外,沒意外的話,chakra可能跟arch一樣,/usr/lib64、/lib、/lib64都只是/usr/lib的軟連結而已。
雖然您說qt和gtk都好像有問題,但是您列的kate、vlc、smplayer、skype、kickoff、system setting都好像是qt程式?
先假設qt程式有問題好了,試試qtconfig -> interface分頁底下 的XIM input style和Default Input Method
maxwux
posted: 28
5subject: Promote 0 Bookmark 02013-04-11quote
哎呀!我忘記檢查qtconfig這一項了
謝謝hyslion
改好後就都OK了!!!
太感謝你了
hyslion
posted: 36
promoted: 2
6subject: Promote 0 Bookmark 02013-04-11quote
maxwux
謝謝hyslion
改好後就都OK了!!!
太感謝你了
不客氣囉,max大,我也是過來人 XD
