gcin on Linux Mint problems
chichen
posted: 5
1subject: gcin on Linux Mint problemsPromote 0 Bookmark 02012-08-29quote
Hi there,
I used to use Fedora 14 + gcin and everything goes well. I like gcin very much. Unfortunately, gcin seems to have all kinds of problems with newer distributions. Recently I installed Linux Mint 13 Xfce 64-bit on my laptop. I first tried apt-get then the package on https://sites.google.com/site/gcinpackagebycoolcd/ .  Both seem successfully done. The two gcin icons (the blue and while one and the En) are shown on my panel and I can invoke gcin-tools all right. The problems are when I type "ctrl + space" the En icon won't change. After invoking gcin-tools, the En icon does change into a Chinese character. However, no Chinese character came out with it. I tried firefox, gedit, emacs, libreoffice. Nothing works. By the way, once the Chinese character icon appears, "ctrl + space" won't change it back to En, either. I like to type in Chinese but can't do it right now. Please help.
2subject: Promote 0 Bookmark 02012-08-29quote
先看
Ubuntu 12.04
改用上面的 repository 看看,如果不想用 repository,也可以手動下載用 dpkg -i install
可能是 distribution 內附的 gcin 有問題
還有千萬不要 install im-config,install 之後就完了,需要用手工做修正的動作
chichen
posted: 5
3subject: Promote 0 Bookmark 02012-08-30quote
感謝回覆。把原先兩種方法安裝去除,再用 apt-get 再裝一次,不知如何就可以了。或許是有登出或重開機或加裝中文套件 (原先用英文安裝) 之故。但 gnome 系統的軟體還是不行, firefox, thunderbird, konsole, kate, libreoffice 則已可以正常使用。網路上 (http://askubuntu.com/questions/106586/gnome-application-doesnt-use-the-system-input-method) 有篇說要用 ibus 改。試了一下,但沒有 gcin 可選。請問要如何讓 gnome 系軟體也能正常使用 gcin? 也利用此機會感謝開發維護 gcin 的各位大大,真的很好用。
4subject: Promote 0 Bookmark 02012-08-30quote
需要 install gcin-gtk3-immodule
chichen
posted: 5
5subject: Promote 0 Bookmark 02012-08-30quote
po 上篇回覆之前已有安裝 gcin-gtk3-immodule. 但 gcin 不能用於 gedit 等軟體,用 ibus 試圖改,也看不到 gcin 的輸入法。
6subject: Promote 0 Bookmark 02012-08-31quote
你是不是用我的 gcin repository ? 我記得之前 ubuntu 內建的 gcin deb 似乎 gtk3 im module install 的步驟不完整。用 terminal 執行
sudo /usr/bin/gtk-query-immodules-3.0 --update-cache
有沒有設定語言中的輸入法?
ls -l ~/.xinput.d/zh_TW
/home/xxxx/.xinput.d/zh_TW -> /etc/X11/xinit/xinput.d/gcin
如果有 install im-config, 設定就會亂掉,移除也沒用,必須手動修正。
chichen
posted: 5
7subject: Promote 0 Bookmark 02012-09-02quote
不是用您的 gcin repository 因 build-in 的 repository 就可以用於 non-gnome 的軟體了,只是不確定為何一開始不行。我 check 後沒有裝 im-config. 依您上述建議做了些修正,似乎 sudo /usr/bin/gtk-query-immodules-3.0 --update-cache 是關鍵,現在可在 gedit 輸入中文了。非常感謝。不過 emacs 下仍不能輸入中文,影響不大,但好奇不知有無解法?
chichen
posted: 5
8subject: Promote 0 Bookmark 02012-09-11quote
今天又有意外發現,之前以為裝 ibus 沒用,所以剛把它移除,結果立刻不能在  gedit and gnome terminal 用 gcin 輸入中文,再裝回來就又可以了。雖然我用 root 權限下了 im-switch -s gcin 指令, ibus 的輸入法中也找不到 gcin, 登入時也無 ibus 圖示,但在我的情況,有裝 ibus 變成能在  gedit and gnome terminal 用 gcin 輸入中文的必要條件,似乎與之前某些人的發現剛好相反 (http://www.ubuntu-tw.org/modules/newbb/viewtopic.php?post_id=205198), 不知能否給此論壇前輩們什麼線索?在我移除與再安裝 ibus 之間,絕對沒有其他動作,僅登入登出及測試中文輸入而已。另 emacs 仍找不到能用 gcin 輸入中文的方法 Frown。
9subject: Promote 0 Bookmark 02012-09-11quote
我在 ubuntu 12.04 把 ibus 移除 gcin 仍然可以使用
mandrake_tw
posted: 23
10subject: Promote 0 Bookmark 02012-11-27quote
我剛才才又裝了一次Linux Minit 13 maya MATE
裝好後還沒有gcin 我用它的軟體管理尋找就有看見gcin 安裝上去就有出現一大堆的輸入法可選了 當然不是每個都可以用的啦
再來我把我慣用的大易的cin 用SSH傳過去(openssh default也沒裝Orz)然後gcin2tab它就可以用了
不過我是在它的文字處理叫什麼忘了,至於在它的Terminal中好像呼叫不出來,不知道是不是要換別種Terminal才可以我還沒試。
後來我想說順便也把日文輸入調一下因為預設好像沒裝上它一啟動GCIN設定就會有一些的錯誤,後來我找找發現是要安裝gcin-anthy這個套件即可,裝好以後就可以給我打あいうえお...
