On the screen display volume mixer for LXDE: volume-osd
1subject: On the screen display volume mixer for LXDE: volume-osdPromote 0 Bookmark 02012-07-29quote
Only support ALSA library
Source:volume-osd.tbz
i386 binary executable: volume-osd strip size:9784 bytes → tiny
chmod 755 volume-osd
sudo cp volume-osd /usr/bin
~/.config/openbox/lxde-rc.xml
<!-- Keybinding for Volume management -->
  <keybind key="XF86AudioRaiseVolume">
     <action name="Execute">
      <command>volume-osd up</command>
    </action>
  </keybind>
  <keybind key="XF86AudioLowerVolume">
       <command>volume-osd down</command>
    </action>
  </keybind>
  <keybind key="XF86AudioMute">
       <command>volume-osd mute</command>
    </action>
  </keybind>
2subject: Promote 0 Bookmark 02012-08-23quote
改成 Mute 之後按 volume↓ 不會解除 mute,可以降低 volume
Lubuntu 是用
~/.config/openbox/lubuntu-rc.xml
3subject: Promote 0 Bookmark 02012-08-24quote
又出新版了,解決了 youtube 全螢幕時調整音量會關閉全螢幕的問題。
4subject: Promote 0 Bookmark 02012-09-04quote
又有新版了,改進了 window 跳動的問題。
5subject: Promote 0 Bookmark 02012-09-05quote
volume-osd.tbz 忘了 update。
