Can gcin-2.6.8 support QT Embedded 4.7.1 (ARM) on Linux frame buffer?
1subject: Can gcin-2.6.8 support QT Embedded 4.7.1 (ARM) on Linux frame buffer?Promote 0 Bookmark 02011-12-29quote
When compile, I got the error message:
In file included from im-gcin-qt.cpp:9:
gcin-imcontext-qt.h:17: error: 'XEvent' has not been declared
make: *** [im-gcin-qt.o] Error 1
I don't use X for QT.
Thanks!
2subject: Promote 0 Bookmark 02011-12-29quote
gcin has gtk win32/IME port, so I think it's not too diffcult to port it to Linux frame buffer.
You must replace the function
bool x11FilterEvent (QWidget *widget, XEvent *event);
with a similar function in Qt/framebuffer.
Please refer to the examples of QT IM module in QT/framebuffer. I don't have any experience in QT/framebuffer.
3subject: Promote 0 Bookmark 02011-12-29quote
Thanks for the feedback.
But since I am new for both QT and gcin, I have trouble to modify it now.
From QT example (/QT/qt-everywhere-opensource-src-4.7.1/src/plugins/inputmethods/imsw-multi),
the function x11FilterEvent() is disable and use the function filterEvent(), but I have no idea how to
implement this function.
Could you provide more concrete example so that I can modify the code? Thanks!
4subject: Promote 0 Bookmark 02011-12-29quote
Please ask the QT team if such examples exist on QT/framebuffer.
