請幫忙解決 64bit-portability-issue
swyear
posted: 127
promoted: 4
1subject: 請幫忙解決 64bit-portability-issuePromote 0 Bookmark 02011-06-05quote
目前 1.6.4pre16 還有一些地方會出現 64bit-portability-issue
E: gcin 64bit-portability-issue eggtrayicon.cpp:247, 344, 367
E: gcin 64bit-portability-issue gcin-setup-gtab.cpp:170, 205
E: gcin 64bit-portability-issue gcin-setup-list.cpp:504, 542, 580
E: gcin 64bit-portability-issue gcin-setup-pho.cpp:328, 351, 390
E: gcin 64bit-portability-issue gcin-setup.cpp:536
E: gcin 64bit-portability-issue tslearn.cpp:236
E: gcin 64bit-portability-issue win-int.cpp:52
從 buildlog 找出來是在這些地方
eggtrayicon.cpp: In function 'egg_tray_icon_unrealize':
eggtrayicon.cpp:247:14: warning: assignment makes pointer from integer without a cast [enabled by default]
eggtrayicon.cpp: In function 'egg_tray_icon_update_manager_window':
eggtrayicon.cpp:344:14: warning: assignment makes pointer from integer without a cast [enabled by default]
eggtrayicon.cpp: In function 'egg_tray_icon_manager_window_destroyed':
eggtrayicon.cpp:367:10: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup-gtab.cpp: In function 'create_spc_opts':
gcin-setup-gtab.cpp:170:16: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup-gtab.cpp: In function 'create_auto_select_by_phrase_opts':
gcin-setup-gtab.cpp:205:29: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup-list.cpp: In function 'create_im_toggle_keys':
gcin-setup-list.cpp:504:22: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup-list.cpp: In function 'create_speaker_opts':
gcin-setup-list.cpp:542:20: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup-list.cpp: In function 'create_gcb_pos_opts':
gcin-setup-list.cpp:580:15: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup-pho.cpp: In function 'create_kbm_opts':
gcin-setup-pho.cpp:328:16: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup-pho.cpp:351:15: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup-pho.cpp: In function 'create_eng_ch_opts':
gcin-setup-pho.cpp:390:19: warning: assignment makes pointer from integer without a cast [enabled by default]
gcin-setup.cpp: In function 'create_gcin_edit_display':
gcin-setup.cpp:536:25: warning: assignment makes pointer from integer without a cast [enabled by default]
tslearn.cpp: In function 'create_pho_sel_area':
tslearn.cpp:236:24: warning: assignment makes pointer from integer without a cast [enabled by default]
win-int.cpp: In function 'create_int_opts':
win-int.cpp:52:16: warning: assignment makes pointer from integer without a cast [enabled by default]
希望老大有空修正一下
2subject: Promote 0 Bookmark 02011-06-05quote
懷疑是你的 build environment .h 太舊的問題。我看 function 都有 prototype
用 make eggtrayicon.E 可以看到 function 都有 prototype 的宣告,請確認 eggtrayicon.E 是否有藍色的這一行
eggtrayicon.E
GdkWindow* gdk_window_lookup_for_display (GdkDisplay *display,
          GdkNativeWindow anid);
static void
egg_tray_icon_unrealize (GtkWidget *widget)
  EggTrayIcon *icon = ((((EggTrayIcon*) g_type_check_instance_cast ((GTypeInstance*) ((widget)), ((egg_tray_icon_get_type ()))))));
  GdkWindow *root_window;
  if (icon->manager_window != 0L)
      GdkWindow *gdkwin;
      gdkwin = gdk_window_lookup_for_display (gtk_widget_get_display (widget),
                                              icon->manager_window);
swyear
posted: 127
promoted: 4
3subject: Promote 0 Bookmark 02011-06-05quote
謝謝版主回覆
看起來的確是編譯環境的關係
在 Open Build Service 的 openSUSE 11.4 環境可以看到
+ cat eggtrayicon.E
+ grep gdk_window_lookup_for_display
      gdkwin = gdk_window_lookup_for_display (gtk_widget_get_display (((((GtkWidget*) g_type_check_instance_cast ((GTypeInstance*) ((icon)), ((gtk_widget_get_type ()))))))),
但是在 openSUSE Factory 中只看到
+ cat eggtrayicon.E
應該是OBS有問題
謝謝您的回答
swyear
posted: 127
promoted: 4
4subject: Promote 0 Bookmark 02011-06-05quote
報告老大:
openSUSE Factory 用了 gtk2.24
而上面那些出現 64bit issue 的似乎都是用到了過期函數
http://developer.gnome.org/gdk/stable/gdk-X-Window-System-Interaction.html
像是 gdk_window_lookup_for_display
gtk_combo_box_new_text
可能要請您先預備一下了
5subject: Promote 0 Bookmark 02011-06-06quote
swyear
之前為了 GTK+ 3.x 已經把這些函數都搞定了,不過有的版本偵測是限定在 >= 2.9x 。
本來是放在 gcin.h, 不過 gcin 1.6.4.pre18 以上版本移到了 gcin-gtk-compatible.h,
如果還是有問題可以調整 gcin-gtk-compatible.h 裡的版本偵測。
GTK+ 2.x 官方預定最終版本就停留在 2.24 系列,不會有 2.25 / 2.26 等等。
swyear
posted: 127
promoted: 4
6subject: Promote 0 Bookmark 02011-06-07quote
謝謝大家,1.6.4.pre18 已經可以在 gtk2.24 編譯了
