cht電腦資訊SQL DB
postgresql 的 SELECT LIKE bug
1subject: postgresql 的 SELECT LIKE bugPromote 0 Bookmark 02007-12-19quote
理論上 SELECT LIKE 'xxxx%' 應該可以用 INDEX search,結果沒有,不知道為什麼?
難道與 PRIMARY KEY 有關?還是 bug ?
db =# explain SELECT seq FROM tab WHERE str like 'edt%';
                        QUERY PLAN
 Seq Scan on tab  (cost=0.00..6465.55 rows=1 width=4)
   Filter: (str ~~ 'edt%'::text)
(2 rows)
db=# explain SELECT seq FROM tab WHERE str = 'edta';
                                  QUERY PLAN
 Index Scan using tab_pkey on tab  (cost=0.00..8.30 rows=1 width=4)
   Index Cond: (str = 'edta'::text)
(2 rows)
2subject: Promote 0 Bookmark 02007-12-19quote
發了 bug report 給 postgresql
3subject: Promote 0 Bookmark 02007-12-21quote
It's not bug. a LIKE 'some%' is different operation than a = str_const. if you don't use C locale, then you have to use varchar_pattern_ops. please try:
create index like_index on tab(str varchar_pattern_ops);
don't forget do ANALYZE tab before Regards Pavel Stehule
原來是要這樣。
cht電腦資訊SQL DB
