cht電腦資訊gcin已解決問題
gcin 64bit-portability-issue again
swyear
posted: 127
promoted: 4
1subject: gcin 64bit-portability-issue againPromote 0 Bookmark 02010-09-11quote
在 openSUSE Build Service 上編譯
出現
 E: gcin 64bit-portability-issue tray.cpp:409
在 log 中可找到的相關資訊為
 gcc -x c -DUNIX=1  -O -pthread -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng12   -I./IMdkit/include -I./im-client -DDEBUG="0" -DGCIN_TABLE_DIR=\"/usr/share/gcin/table\" -DGCIN_OGG_DIR=\"/usr/share/gcin/ogg\" -DDOC_DIR=\"/usr/share/doc/packages/gcin\" -DGCIN_ICON_DIR=\"/usr/share/icons/gcin\" -DGCIN_VERSION=\"1.5.6.pre8\" -DGCIN_SCRIPT_DIR=\"/usr/share/gcin/script\" -DGCIN_BIN_DIR=\"/usr/bin\" -DSYS_ICON_DIR=\"/usr/share/icons\" -DFREEBSD=0 -DMAC_OS=0 -DG_DISABLE_SINGLE_INCLUDES -DG_DISABLE_DEPRECATED -DGDK_DISABLE_SINGLE_INCLUDES -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_SINGLE_INCLUDES -DGTK_DISABLE_DEPRECATED -DUSE_XIM=1 -DTRAY_ENABLED=1 -DGCIN_i18n_message=1 -DUSE_TSIN=1 -DUSE_ANTHY=1 -DUSE_GCB=1 -c tray.cpp
tray.cpp: In function 'create_tray':
tray.cpp:409:6: warning: assignment makes pointer from integer without a cast
麻煩各位大哥幫忙一下
2subject: Promote 0 Bookmark 02010-09-11quote
以前怎麼沒有這個問題?
#include <signal.h>
#include "gst.h"
#include <gdk/gdk.h>
swyear
posted: 127
promoted: 4
3subject: Promote 0 Bookmark 02010-09-11quote
tray.cpp:410:6: warning: assignment makes pointer from integer without a cast
報告:
加了那行結果由 409->410 ^^
沒用ㄟ
其實這個問題出現一陣子了
但是是在 Factory (openSUSE 的開發版本)裡出現的
所以我就拖著沒來問
還是麻煩您了
4subject: Promote 0 Bookmark 02010-09-11quote
make tray.E
tray.E 裏面是否有
GType gdk_gc_get_type (void) __attribute__((__const__));
GdkGC *gdk_gc_new (GdkDrawable *drawable);
GdkGC *gdk_gc_new_with_values (GdkDrawable *drawable,
       GdkGCValues *values,
       GdkGCValuesMask values_mask);
swyear
posted: 127
promoted: 4
5subject: Promote 0 Bookmark 02010-09-12quote
好像沒有
完整的 tray.E 如附檔
6subject: Promote 0 Bookmark 02010-09-12quote
那可能是
gdkgc.h 缺
如果無法修正這個問題,自己在 tray.c 加入  GdkGC *gdk_gc_new (GdkDrawable *drawable);
也可以
swyear
posted: 127
promoted: 4
7subject: Promote 0 Bookmark 02010-09-12quote
現在已經正常了
應該就是您說的問題
感謝
cht電腦資訊gcin已解決問題
