enComputerevilvte
bug: MATCH_STRING_EXEC prevents text selection
aragon
posted: 5
1subject: bug: MATCH_STRING_EXEC prevents text selectionPromote 0 Bookmark 02010-04-18quote
Hi,
I noticed a bug with the new MATCH_STRING_EXEC option.  When enabled it makes it impossible to select text with the mouse.  Not sure how to fix it.
Regards,
Aragon
2subject: bug: MATCH_STRING_EXEC prevents text selectionPromote 0 Bookmark 02010-04-19quote
It is the feature of libvte.
There is no convenient way to fix it.
Maybe you can #define MENU_MATCH_STRING_EXEC and right-click to choose "Copy" the matched string. :-)
aragon
posted: 5
3subject: Promote 0 Bookmark 02010-04-21quote
Hey.  I believe I have the fix for this.  I've also fixed another bug I discovered.  First the other bug:
URIs with "&" in them get cut off just before the "&".  Modified the system() string to enclose the URI in single quotes and it works.  Patch attached.
For the original bug, looks like the return of menu_popup() just needs to be tweaked.  If VTE reports no matched URI on a button press, return FALSE (instead of TRUE).  You'll see this in my patch.
My patch also changes the URI click button to 2 (middle click).  This is a better idea IMHO, and it's how at least one other VTE based term does things.
Hope you like. :)
enComputerevilvte
