cht電腦資訊影音版
SVG Color 1.2
ziyawu
posted: 101
promoted: 69
1subject: SVG Color 1.2Promote 1 Bookmark 12009-10-02quote
今天打開信箱就看到一封令人振奮的信,W3C 終於釋出 SVG Color 1.2 的規格。Inkscape 開發人員應該很激動...
信件內容如下:
Finally!!!! SVG 1.2 color stuff is out in the wild. (Well, specs at
least)
"...The implication of this is that it is possible to use a fully
colormanaged workflow (using SVG 1.0 onwards) that supports a full
CMYK pipeline via the use of ICC profiles."
"...SVG Color introduces the ability to use so-called 'named' or
'spot' colors. Named colors are used in many print applications and
are supported in SVG Print through the use of ICC named color profiles."
http://www.w3.org/TR/2009/WD-SVGColorPrimer12-20091001/
http://www.w3.org/TR/2009/WD-SVGColor12-20091001/
Inkscape 快點支援 CMYK 吧!
Libre Graphic Meeting 2009 的 Inkscape 方面除了提到 0.47 版開發週期變長的原因之外,就是一直在說色彩管理和 CMYK。
0.48 會有驚喜嗎?
Libre Graphic Meeting 2009 影片網址
ziyawu on deviantART
cht電腦資訊影音版
