cht電腦資訊網路
Google Chrome 也有擴充套件了
1subject: Google Chrome 也有擴充套件了Promote 0 Bookmark 02009-05-31quote
根據 The First Google Chrome Extensions: Block Ads, Check PageRank, and Use IE8 Accelerators
Google Chrome 的擴充套件架構的特點如下:
  • 使用 javascript, css, html
  • 安裝後不必重新啟動就可以用
  • extensions 將可相容於所有未來的 Chrome 版本
  • 每個 extension 都會單獨跑一個 process
  • extension 可以出現在瀏覽器的底部
  • google 會控制 extension 的 button 的外觀,以維持介面的一致性
  • google 會建立一個 extension gallery,讓開發者可以上傳他們的作品、使用者可以找到他們需要的 extensions
看起來蠻不錯的樣子
2subject: Promote 0 Bookmark 02009-05-31quote
我比較想要每個 Tab都是獨立的 process,這樣某個 Tab掛掉就不會整個browser 都掛。聽說新的 firefox會支援這個。
只是這樣會不會很吃 memory?
3subject: Promote 0 Bookmark 02009-05-31quote
我只希望能有個精簡型的 web browser(不是 dilo 那麼陽春的),啟動快,反應速度也快,一些延伸功能倒是可有可無。
有這種 browser 嗎?我目前有這種需求的時候都是用 w3m。
4subject: Promote 0 Bookmark 02009-05-31quote
chrome 2 有個蠻酷的功能
把分頁拖到螢幕四週或視窗四週的中央,會出現一個方塊,放開滑鼠,就可以重新 resize 視窗。
http://www.google.com/support/chrome/bin/answer.py?hl=en&answer=95622
Resize tabs
Drag a tab to pre-defined locations, or docking positions, on your computer monitor or browser window to quickly resize your browser window. When the docking icon appears, release the mouse over the icon to have the tab snap in place.
Here are the different docking positions:
  1. The top of your monitor, in the middle: The tab appears maximized in a new window when you release it.
  2. The bottom of your monitor, in the middle: The tab appears in a new window that fills the lower half of your monitor.
  3. The left and right sides of your monitor, in the middle: The tab opens in a new window that fills up either the left or right half of your monitor.
  4. The bottom of a browser window, in the middle: The tab appears in a new window below the existing browser window. The two windows splits the monitor in half.
  5. The left and right sides of a browser window, in the middle: The tab opens in a new window that fills up either the left or right half of your monitor. The existing browser window takes up the other half of the monitor, so that the two windows appear side-by-side.
5subject: Promote 1 Bookmark 12009-06-03quote
可以試試 k-meleon
不過可能還不夠精簡就是了……
6subject: Promote 0 Bookmark 02009-06-05quote
Google 真的會容許 Ad-blocker 這種東西出現嗎?
cht電腦資訊網路
