best place to put environment variables for X11
yuriy
posted: 14
Denver,CO,USA
1subject: best place to put environment variables for X11Promote 0 Bookmark 02009-05-13quote
Which is the best place?
2subject: Promote 0 Bookmark 02009-05-13quote
.xinitrc (start X from console)
or
.xsession (start X with display manager, such gdm, kdm, xdm)
Those two files works for all X11 implements.
However, some distributions may suggest you to use something like .gnomerc / .kderc or similar files.
3subject: Promote 0 Bookmark 02009-05-13quote
Some distributions supports .xsessionrc now (alone side with .xsession).
Thanks to Solomon.
I have not use these stuffs for over 4 years. (I run "~$ X &" directly from console)
yuriy
posted: 14
Denver,CO,USA
4subject: Promote 0 Bookmark 02009-05-13quote
I put these 2 settings in .xinitrc
Pidgin works fine . I can activate  pinyin.gtab and symbols.gtab (ctrl + alt + 4)
gedit is okey too. but when I use skype I cannot switch to pinyin mode or activate symbols.gtab
Only If I will open gedit (empty file) I can activate symbols.gtab and after I can use virtual keyboard with skype.
Any ideas?Please see .Xsessions.errors file
Thanks
5subject: Promote 0 Bookmark 02009-05-13quote
Your system starts the input method server "/etc/X11/xinit/xinput.d/default".
But gcin restarted (or starts the first time) later:
XGetSelectionOwner: old version of gcin or gcin is not running ??
... try to start a new gcin server /usr/bin/gcin
Maybe your /etc/X11/xinit/xinput.d/default is not gcin?
yuriy
posted: 14
Denver,CO,USA
6subject: Promote 0 Bookmark 02009-05-13quote
Let see this file ....
What I should change there?
