gcin virtual keyboard + russian layout
1subject: gcin virtual keyboard + russian layoutPromote 0 Bookmark 02009-05-09quote
Hello there,
Can I can make GCIN virtual keyboard to support russian layout? Is it posible ?
With best regards Yuriy
2subject: Promote 0 Bookmark 02009-05-09quote
You may want to try this one:
http://hyperrate.com/thread.php?tid=9628 (a simplified virtual keyboard)
download: http://hyperrate.com/topic-files-dir/28/9628-_o7bmhGLaF/gvkbd-0.0.1.tar.gz
It is basically the same with gcin's virtual keyboard.
Currently, you have to patch gcin and rebuild it to have russian layout.
3subject: Promote 0 Bookmark 02009-05-09quote
Do you want to input chinese ?
4subject: Russian layoutPromote 0 Bookmark 02009-05-09quote
Sure I use GCIN to input Chinese. I think GCIN is the best Chinese input system.
I type in Russian (very seldom ) so it will be perfect to convert gcin's virtual keyboard to support Rassian layout (Windows -1251)
5subject: Promote 0 Bookmark 02009-05-10quote
Please refer to the attached symbols.cin.
This is the definition of the keyboard when you press ctrl-alt-4 for symbol input.
yuriy
posted: 14
Denver,CO,USA
6subject: Promote 0 Bookmark 02009-05-10quote
謝謝你 for helping me ...... Looks like virtual keyboard support Russian keyboard layout by itself ... only what I need to replace English letters by Russian letters ob virtual keyboard ... I tried to patch /usr/bin/gcin by using biew (which support Russian code pages) but after restart gcin
I dont see Russian letters on virtual keyboard ......
7subject: Promote 0 Bookmark 02009-05-11quote
why don't you try the symbols.cin
  • modify text file 'symbols.cin' to support russian characters.
  • gcin2tab symbols.cin
  • cp symbols.gtab ~/.gcin
press ctrl-alt-4
yuriy
posted: 14
Denver,CO,USA
8subject: Promote 0 Bookmark 02009-05-11quote
謝謝 спасибо Perfect!!! Works very good, thanks!
9subject: Promote 0 Bookmark 02009-05-11quote
Post the .cin file.
yuriy
posted: 14
Denver,CO,USA
10subject: Promote 0 Bookmark 02009-05-11quote
Do you mean symbols.cin?
Sure. I use gcin on Ubuntu. I noticed sometimes 2 copies of gcin are running in the same time.I tried to kill it (by using
kill -9 (gcin ID) but I cannot do it. Is it bug ? or maybe my setting is not correct?
11subject: Promote 0 Bookmark 02009-05-11quote
1. Did the two gcin have the same uid ?
2. another possibilty is the env variable XMODIFIERS is set multiples times in different places. Gcin use this variable to bind connection. If no gcin exists in this XMODIFIERS,it will execute a new gcin automatically.
You can view /proc/pid_of_gcin/environ to check the value of  XMODIFIERS。
12subject: Promote 0 Bookmark 02009-05-11quote
If you don't want the virtual keyboard to hide automatically.  Delete this line in symbols.cin
   %symbol_kbm
You have to press middle button at the gcin tray icon to show the virtual keyboard window.
yuriy
posted: 14
Denver,CO,USA
13subject: Promote 0 Bookmark 02009-05-11quote
after when I restart firefox I can see 2 copies of GCIN (3729 & 3377 ps ID)
HOME=/rootPATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/X11R6/binDISPLAY=:0.0LANG=en_US.UTF-8XAUTHORITY=/tmp/libgksu-mAp0aN/.XauthorityDISPLAY=:0.0SHELL=/bin/bashLOGNAME=rootUSER=rootUSERNAME=rootTERM=unknownSUDO_COMMAND=/usr/sbin/synapticSUDO_USER=yuriySUDO_UID=1000SUDO_GID=1000yuriy@yuriy-des
GNOME_KEYRING_PID=3114USER=yuriyGNOME_KEYRING_SOCKET=/tmp/keyring-fOLdIg/socketSSH_AGENT_PID=3182HOME=/home/yuriyXDG_SESSION_COOKIE=61ecab4867080305bca001dc4a018eb8-1242074038.238680-1588417484DESKTOP_SESSION=defaultGTK_MODULES=canberra-gtk-moduleDBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-yL5g6RfIFY,guid=e39875d91ce40a2e366462ab4a088bb7GDM_XSERVER_LOCATION=localLOGNAME=yuriyGTK_IM_MODULE=gcinUSERNAME=yuriyWINDOWPATH=7GDM_LANG=en_US.UTF-8PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/gamesDISPLAY=:0.0LANG=en_US.UTF-8XAUTHORITY=/home/yuriy/.XauthorityXMODIFIERS=@im=GCINSSH_AUTH_SOCK=/tmp/keyring-fOLdIg/socket.sshSHELL=/bin/bashGDMSESSION=defaultQT_IM_MODULE=gcinPWD=/home/yuriyXDG_DATA_DIRS=/usr/local/share/:/usr/share/:/usr/share/gdm/GPG_AGENT_INFO=/tmp/seahorse-N1pKZQ/S.gpg-agent:3209:1GNOME_DESKTOP_SESSION_ID=this-is-deprecatedSESSION_MANAGER=local/yuriy-desktop:/tmp/.ICE-unix/3127ORBIT_SOCKETDIR=/tmp/orbit-yuriyGTK_RC_FILES=/etc/gtk/gtkrc:/home/yuriy/.gtkrc-1.2-gnome2DISPLAY=:0.0
14subject: Promote 0 Bookmark 02009-05-12quote
You may run
~$ ps ax | grep gcin
and see if one or more gcin are <defunct> or zombies.
It happens when one or more gcin were crashed.
GTK+ immodule system will restart gcin automatically.
yuriy
posted: 14
Denver,CO,USA
15subject: Promote 0 Bookmark 02009-05-12quote
I installed gcin 1.4.5~pre7-0~2+solomon
is this build comes with gcb (Gtk copy-paste buffer) ? How I can deactivate gcb?
Thanks!
I found it .......
yuriy
posted: 14
Denver,CO,USA
16subject: Promote 0 Bookmark 02009-05-12quote
But second copy of gcin still exist I'm not sure why its starts.
ps ax | grep gcin
3294 ? S 0:03 gcin
4809 ? S 0:00 gcin
4971 pts/0 R+ 0:00 grep gcin
17subject: Promote 0 Bookmark 02009-05-13quote
~$ grep  -a --color XMODIFIERS /proc/$PID/environ
(substitute $PID with your gcin process PID)
for example, grep  -a --color XMODIFIERS /proc/4809/environ
It should be none or "XMODIFIERS=@im=gcin" by default.
One user and one XMODIFIERS value may only have one gcin server running.
If your two gcin servers have different XMODIFIERS values, you may find where it come from with the hint.
yuriy
posted: 14
Denver,CO,USA
18subject: Promote 0 Bookmark 02009-05-13quote
one thing more I use  gcin 1.4.5~pre7-0~2+solomon and I noticed , when I want to  use short key (cntrl + H) in gnome file manager , I cannot use it . by pressing any key  I have open "search" window Looks like all short keys are disabled ....
I mean gcin 1.4.2-1 doesn't has this problem ...
yuriy
posted: 14
Denver,CO,USA
20subject: Promote 0 Bookmark 02009-05-13quote
GNOME_KEYRING_PID=3082USER=yuriyGNOME_KEYRING_SOCKET=/tmp/keyring-Ss21rg/socketSSH_AGENT_PID=3150HOME=/home/yuriyXDG_SESSION_COOKIE=5f6cebbf023adf39f4c70c634a087998-1242177857.118395-1943361764DESKTOP_SESSION=defaultGTK_MODULES=canberra-gtk-moduleDBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-melKjSzi4p,guid=9179dba3a1d85af71f35d4b04a0a2142GDM_XSERVER_LOCATION=localLOGNAME=yuriyGTK_IM_MODULE=gcinUSERNAME=yuriyWINDOWPATH=7GDM_LANG=en_US.UTF-8PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/gamesDISPLAY=:0.0LANG=en_US.UTF-8XAUTHORITY=/home/yuriy/.XauthorityXMODIFIERS=@im=GCINSSH_AUTH_SOCK=/tmp/keyring-Ss21rg/socket.sshSHELL=/bin/bashGDMSESSION=defaultPWD=/home/yuriyXDG_DATA_DIRS=/usr/local/share/:/usr/share/:/usr/share/gdm/GPG_AGENT_INFO=/tmp/seahorse-zsvgBs/S.gpg-agent:3176:1GNOME_DESKTOP_SESSION_ID=this-is-deprecatedSESSION_MANAGER=local/yuriy-desktop:/tmp/.ICE-unix/3095ORBIT_SOCKETDIR=/tmp/orbit-yuriyGTK_RC_FILES=/etc/gtk/gtkrc:/home/yuriy/.gtkrc-1.2-gnome2DISPLAY=:0.0
so XMODIFIERS = @im=GCINSSH_AUTH_SOCK is wrong
 my .profile has these settings
export GTK_IM_MODULE=gcin
export XMODIFIERS='@im=GCIN'
correct?
